Lyrics is not showing anymore
I love the player, the first time I used it, I was surprised because it’s the only player that displays lyrics so that you can sing along.
But, the problem is, lyrics are not showing anymore.
How can I fix this?
What program do I need to install for the lyrics to show up again.
Please help. I hope this thread for Cometplayer is still alive.
Hi Jerry, which version is your CometPlayer?
What, exactly, do you mean by the lyrics “not showing up anymore”?
If you mean that the window displaying them isn’t there, then you need to click on the CometPlayer logo at the top left (this is just like Winamp), then from the menu select “Panel” and check the “Lyrics” choice.
