Make torrent properties window more useful.
Sometimes torrent can have thousands of files and size of all of them can exceed 1 terabyte and higher, but if I want to download only one particular file I must search it manually and if torrent has tons of directories it is practically almost impossible to find that file. The worst thing that every time I open such torrent all directories are expanded, this makes sorting by clicking on the columns absolutely useless. So I ask to add new features to the torrent properties window:
  1. Add option to collapse all directories in one click and also add choice in the options for all new torrents being opened with collapsed directories by default.
  2. Add search box with filter ability, so, for example, if I write there some word, then only files with this word in their names will be shown, so I can select only these files.
A search box would be very useful indeed!
