Making_MultiFile webseed torrents_with_bitcomet
Hello
iam trying to make one torrent file for multifile download from webseed
i make the torrent file with utorrent but notworking
work just for one file torrent
utorrent have webseed box for url list i add all link in webseed box but notworking
it work just for one file download
how can i do that with Bitcomet or any good way
my all files here
My link
also try with bitcomet but notworking maybe need something here
any way
Thanks 4 Help
Peace
G.Kamel
I would not expect a .torrent made with utorrent to be compatible as far as the web seeding operation. Regular torrenting, yes, but not web seeding. There is no agreed standard way to do this. Try remaking the torrent with BitComet and see if that works better.
Thanks
i found burnbit.com website help me to make torrent file but not multifile torrent
do you think bitcomet better than burnbit.com
do i need tracker for webseed torrent
can you make one torrent file for me if you have time
i have try to make one torrent file for multifile webseed torrent not working with bitcomet
you can try with my files here
My Files
thanks for help
Peace
G.Kamel
We had a very long discussion about this, and yes, BitComet supports multiple webseed links in a torrent, as long as the files being seeded are hosted at the same location, just leave the file names off the url, if it ends in “/”, bitcomet will download any of the files it finds in that location.
If you use the search, you can find the prior discussions where we tested this, I’m not inclined to go through all that testing again, but if you read it and don’t understand any of it, let us know, we’ll try to explain.
@kluelos, I made a webseeded torrent and it worked with bitcomet and utorrent. I used some mp3 files uploaded to fileden, added the link as a webseed and it downloaded with utorrent and bitcomet equally well.
AFAIK, uTorrent uses the same WebSeeding specification as BitComet which is GetRight specification.
So, at least theoretically, they should not have any issues using each other’s torrents.
The other one, which is BitTornado’s, I’m not sure if it’s implemented in any other client.
Thanks Mr.Admin
so can you help me to do torrent file for multifile torrent webseed with bitcomet
as test you can try this two file here
http://ia700705.us.archive.org/29/items/ALTHEKR/1-Greatest-Miracle.mp4
http://ia700705.us.archive.org/29/items/ALTHEKR/10-Digital-Miracles-in-theHolyQuran.mp4
i try with bitcomet but notworking maybe i forget something here
can you show me how plz
Peace
G.Kamel
I’ve already gone through this once, it’s posted in the forum so I’m not going to repeat this everytime someone asks.
All your questions have been answered, you just need to read them.
Http peers for torrents
Good to know there is a proposed standard out there, but there’s no assurance that anyone has or will continue to abide by it. Let us hope so, there’s been enough anarchy.
When you are making the torrent add this
in web seeding and then try.
DO Not change the file Names.
You may visit the link i gave to you and verify the file names
If you need detailed explanation then you should make a new topic in the forum
