hi! i have a problem, just installed bitcomet and cant get a real speed on my downloads, i have 300kb\s connrction but im never over 20kb\s can anyone help me? its only on bitcomet its slow anywere else i have full speed…
Read and follow the settings guide.
thats all the help i get???thx!
A lot of time has been/is put into the settings guide and FAQ. They take you step by step through setting up BC and getting max speeds. And our guides are always updated. So yes we’re going to tell you to use our guide first with all the info already in it instead of explaining it here in the posts for the billionth time.
Then if you have a problem after that you tell us whats wrong in detail with the error message you get and we’ll help figure out what went wrong where.
I got the same problem and I understand I first need to read the FAQ, but where can I find it? Are they in the programm or on the Internet or somewhere in a map on my computer?
I’m sorry… I already found it, but I haven’t found the answer yet…
maybe someone who had this same problem can help me out? or has someone got a link of a thread where this all is explained?
So I have read the FAQ, but I can’t find the solution to the problem. I havent got a max speed selected, so that can’t be the problem. (limietloos(in dutch) not limited)
The settings guide is in the Guides and How-To’s forum. You need to concentrate on the sections about opening your listen port, and about capping your global maximum upload speed.
