Hi,
In addition to the sorting capability of the files inside the torrent, it would be really cool if one could not only limit the amount of kB/s up- and download speed of each torrent, but also limit the amount of connections for that specifi torrent.
I have some torrents with hundreds of sources and as they are all slow, I would like that one to connect to as many peers as possible. But if you have a maximum total of connections (in my case about 500) and have multiple torrents, then other torrents will use up connections that I don’t want them to use.
Being able to limit the less important torrents to like 10 connections would allow them to download while not disturbing the more important torrents.
Thanks for listening and good night B) ![]()
