morning,
can someone tell me how to get the max of 150 open port’s.
i have troubles using voip calling and i could be that there are to many ports open.
thanks
morning,
thanks
You are mistaken on an issue. Port are only closed by your firewall. And programs should only use 1 port for or a few ports for connections. You should give a lot more information about what you’re doing. Like your OS, your security software, do you have a router, if so what kind.
