"Max Simultaneous Download Tasks" option??!?!!
In the options it has an option: “Max Simutaneous Download Tasks” but if change it to 1 when the first task is completed BC doesn’t start the next task; it continue to upload the first task that was finished which is normal but why it doesn’t start the next task? Only if you deleted the first task when it finished BC start the next that is queued.
The option is “Max Simultaneous Download Tasks” not “Max Simultaneous Started Tasks”?!?!?
So the suggestion could be:
To add another option: “Max Simultaneous Started Tasks”.
The existing option “Max Simultaneous Download Tasks” to be all the tasks that are downloading (task<100%) or are waiting for seeders to show up.
The new option “Max Simultaneous Started Tasks” to be all the tasks that are downloading (task<100%) or are waiting for seeders to show up AND all the tasks that are uploading (task=100%) or are waiting for peers to show up.
Yes, you are right. We will make a modification about that.
