Menu Bar Or Navigation Bar Not Visible
Hi,
I right clicked on the Menu bar and unchecked ‘menu bar’ and ‘navigation toolbar’.
I did this to view more of the content.
Now that I think about it I should of pressed F11 instead to view more
How can I get these two bars back?
Thanks.
Hi Tyrannous,press F10 on your keyboard and the menu bar will appear, then just right click the menu bar to restore the 2 bars by ticking them. :slight_smile:
I got them back now, thank you.
No worries, Tyrannous! :smiley:
