Salutare din nou! Scuze ca nu am mai intrat pe forum, desi e interesul meu. Oricum,folosesc BT din ianuarie,anul trecut. Am avut BT 0.9, 1.10, 1.12 si acum 1.14.
Am avut alta problema cu el: il inchideam si la deschidere nu imi mai aparea nici un torent descarcat (asta la BT 1.12). Am rezolvat-o, am gasit pe forum aceeasi problema. Am sters fisierul ,xml, din locatia BT-ului si nu am mai avut problema aceasta.
Cum zice si Vasy, e vorba de bara de unelte. Cind am instalat BT 1.14, s-a instalat impreuna cu ,games,. A mers foarte bine o perioada, dar acum pe orice ,unealta, dau clic, imi apare un mesaj ,application not found, (chiar si cind vreau sa intru la ,Torrents Sites,).
O sa reinstalez BT-ul, dar ma enerveaza ca nu pricep ce s-a intimplat. M-au sfatuit si prietenii sa dau jos BT 1.16, dar cred ca vreau sa descopar problema (nu sa aleg calea cea mai simpla).
Trebuie sa va spun ca nu ma pricep foarte bine la PC, de fapt sint mai mult autodidact si mai intreb in stinga si dreapta. O sa va tin la curent cu problema mea. Multe multumiri pentru sfaturi!
Hi again! I’m sorry for not sowing up earlier on the forum, although it’s in my best interest to do so. Anyway, I use BC since January, last year. I’ve had BC v0.9, 1.10, 1.12 and now 1.14.
I had another problem with it: all the downloaded torrents where disappearing after closing it (on BC v1.12). I solved the problem, I found the same problem as mine on the forum. I deleted the “xml” file from BC’s location and the problem was solved.
As Vasy says, this is about the toolbar. When I installed BC v1.14, it installed “games” too. It worked very well, for a while, but now I get an error message “application not found” every time I click on any of the “tools” (even if I click on the “Torrent sites”).
I’ll reinstall BC, but it annoys me to not know what happened. My friends advised me to download BC v1.16 too, but I want to discover what causes this problem (I don’t choose the easy way)
I must tell you that I’m not computer savvy, actually I’m more of a self-learner and I tend to ask around too. I’ll keep you updated with my problem. Many thanks for the advices!
