my motorola SBG900 modem router dropsout every so often when im using bitcomet. when i have bit comet shutdown it doesnt drop out so im wondering if i can change the settings so it wont dropout.
“drops out” doesn’t really say much. What does it do, exactly, how do you know, and what do you do to recover it?
Doing a search on google for “motorola SBG900 drops” yields this
http://whirlpool.net.au/forum-replies-arch…cfm/461883.html
one of the suggestions that might help is to turn off the SPI firewall (set it to Open NAT instead of Strict NAT)
there are other suggestions so maybe you will find your answer there
If you are unable to do anything to the router that fixes the problem then here are things you can do with Bitcomets settings
