morpheus vs bitcomet
help me… i have morpheus (another p2p) i use this for small files and mostly audio that i cant find with bitcomet… every time i click to download a file from bitcomet morpheus tries to download it which it cant. it is in idle mode and it doesnt show up in bitcomet. how can i fix this?
it sounds like bit comet is not your default program to open torrent files.
right click on one of your file.torrent, select “properties”
Then next to “open with” change it to bit comet.
Your torrents should now all open with bit comet.
you can also start bit comet then open the torrent file from the menu.
tnx!!! did it! the problem is in morpheus… i changed the preferences.. no prob with bitcomet! tnx!
you are welcome :slight_smile:
just to keep in mind, you could also save the .torrent file somewhere and then open it using BitComet
