Hello all
I don’t know if it is just me or what but my move up and down option does work anymore. If it is suppose to be working can someone tell me how I can fix this in the registery or something?
Thanks
rcla396
Hello all
Thanks
rcla396
Try clicking on the top of the column with the task names a couple times and the buttons should become active.
The reasons are complicated, but if you have your tasks sorted by another column you won’t be able to use the up/down button, but clicking where it says “name” will cycle the sorting order and should get you to the correct sorting to activate the buttons.
I have it working now thanks for your help.
rcla396
