Hi whenever I download a movie from bitcomet and try to view it on my TV via an HDMI cable, the audio plays from my laptop, not my TV, is there any settings I need to adjust ?? thanks for any help nottonto
You’ll need a player that supports hdmi as well as the TV, and it would need to be enabled. I suggest the best place to start is the players support forum.
or you could use a separate audio cable.
