Hi everyone
I have windows xp and all movies play on my computer but when i burn them they either wont start or play half then stop. I thought it might be my burner so i tried usb stick and it does the same thing. any suggestions.
Thanks Roanne
Hi everyone
Thanks Roanne
Please make sure to post in the proper forum.
topic moved to General Questions
Hi everyone
How, exactly?
What do you try to play them with? Do you get any sort of message? What does it say?
or play half
Play half??? What does this mean?
Again, how, exactly?
What software did you use? Well, you may wanna try another tool. The best and most reliable one that I’ve ever used is a tool called DVD Creator. It’s able to burn all kinds of videos to DVD disc. After that, you can view the DVD on DVD player. It also lets you edit videos and create DVD menus. Easy to use and professional.
You should give it a try. Best of luck.
