MPC 4.9 no soundhelp plzz!!!!!!!!!
‘View the pic’ no sound.how to resolve this problem.help plzzzz/monthly_11_2010/post-59180-12887134699407.png" rel=“”>
If you can hear other players/sounds then the issue probably isn’t the volume on MPCStar.
Check the file info and see if you have all of the required decoders.
i can hear sound using other player…
bu not if using mpc star…im noob about this..can just u tell me what i need to do using pic or something.
No, not really. You get pictures and complete guides and all that with software that you buy. Free software doesn’t come with all that stuff because there’s nobody to pay for its creation. If you want to use freeware, you need a lot of initiative and a lot of willingness to teach yourself about computers.
Mostly that will mean that you need to explore and poke around, try different things and learn as you go along.
We’re all volunteers here, donating our time and efforts. We don’t have the resources to create illustrated documentation, or sometimes any documentation at all beyond what came with the program. We can guide you in your efforts to help yourself, but the major burden is still on you to do that.
When did you first noticed that you can’t hear the sound from NPCStar? Did you make any changes to your pc’s sound settings?
This guy wants a problem solving algorithm…
/monthly_11_2010/post-53701-12889031281816.gif" rel=“”>
Solved
I was having the same issue mentioned above. I could see my sound graph in win 7 volume control moving, but no sound.
A friend of mine used my pc and stuffed up my star player somehow. (Think it was muting while playing flash)
Found that if I play a flash file and unmute (In the star player) it solves my problem. Sound issue resolved!!!
Spykz
:lol: :lol: :lol: Vasy, that algorithm is a killer one.
I like it so much I’ve downloaded it.
How it applies to spikkzebaka’s post is even more funny, he could blame a friend of his, so… it goes to no problem.
man daat really worked thanks dude…!!! fell wid d flash…!! i dunno wot aall stuff i hav dun…!!! thnks to ur post… play a flash or swf file… :lol:
im having the same problem right now. how do i fix it ive tryed 4.6 -5.0
flash game… thats the magic fix…dam
