I am currently using my dell studio to watch harry potter (MKV format)
i have no problem playing it on my dekstop…
i tried to play on my laptop …
it wrote “NOW PLAYING”
but the sec is not moving , meaning like 00:00 / 2:22:00
i press (SPACE) to play…
it is playing but the video is not moving…
i try to fast forward to any sec … then i press play again , nothing happens
VIDEO INFORMATION : Harry Potter (MKV FORMAT)
suspect : is it screen size problems?
i have no problem playing mp4 format on my laptop…
MY BRO ARE USING DELL STUDIO and his screen size is slighty bigger than usual laptop.
mine is just a normal laptop screen size.
HELP~~~
Ossie7
2
What are the specifications of your laptop? Not any computer is powerful enough to play big MKV movies.
Dell Studio 1458
Intel® Core i5 CPU M520 @ 2.40 GHz
is it because my screen is too small so i cant play 1080p , i can only play 720p
What is the video codec of the file?
Can you play any 720p file encoded with the same video codec?
What do you mean by “the video is not moving”? Does the video look as a still image (photo) or is it a blank screen?
i can play 720p , just cant play 1080p.
cause when you PLAY/STOP.
there will write PLAY/STOP.
PLAYING ← wrote there…
but not moving , cause starting is 00:00 > 00:01 right? it not moving the sec.
i think is cant play la.
but i don’t receive any error.
my bro dell laptop the screen size is larger than mine , and i have no problems playing on dekstop.
i guess my laptop screen is too small to play 1080p video?
Ossie7
6
screensize should not be the problem, I can run 1080p on a smaller screen aswell.
After a bit of searching I found that your laptop has a some good hardware and should be fine with 1080p movies.
Maybe you can try and get another 1080p movie and see if that one works/
i think that way too…
haihz…all the codec i have…
and my laptop is not old enough should be able to support , i just cant play it.
when i play the HARRY POTTER no error message come out.
it is PLAYING , but just not moving, the screen , the screen picture just STONE there.
