mpcstar playtime ( crono )
Hi all,
On the old mpcstar players there was an option that you could use for seeing the play time in the top left corner,
it was a kind of crono it had houres,minits,seconds and milliseconds.
I alway’s used it to make my own subtitels or translate others when they where out of sync.
and now on the new mpcstar 4.9 i cant find that option no longer.
Could anyone help me here to find another option for this pls.
thanks
Axelle
Elapsed time/Total time is displayed in the bottom left corner of the screen, above the toolbar. Did you mean something else?
yes indeed that is correct
but i ment something else
wat you see at the bottom left corner above the toolbar is only houres/minits and seconds
wat you normaly could do is activate an option so that you would get another timer in the top left corner
stating the exact houres/minits/seconds and milliseconds so that you could edit the subtitels in the .srt file
to the exact millisecond and thats wat one realy needs, those milliseconds :slight_smile:
Hi Axelle, this feature was added long time ago. What version is your MPCStar?
Hi Lucy26,
yes i know but i canot find it any longer :frowning:
and i’m not blonde but perhaps i’m looking in the rong places :huh:
My Mpcstar is the latest one i dlld a few days ago here, 4.9
the tigerplayer is 4.0.9.14
Hi Axelle, which version is the one you used before 4.9? I meant the one with time on the top left corner.
Hi Lucy26,
euh you got me there lol
i cant quiet remember the version nr; i think it was 3.somthing… .4 or 5
cant remember since i had to buy a new hd drive when the old one didnt want to work no longer
that is also how i lost all my data and since then i used the mediaplayer from win untill i came to a
movie with no subtitles thats when i rememberd i used mpcstar so i dlld it again.
But if im not mistaken it has to do with somthing like ffdshow, but i tried that also but failed there also.
wat i can find with ffdshow is how to show the framerate etc. in the top left corner, thats how i know im
close to finding it lol, but its frustrating not able to find it again :angry:
Hi Axelle, the development team will handle your request. Thank you for your support. :slight_smile:
Hi Axelle, please play a video file, and open Files → File Info.
  1. Go to DirectVobSub → Misc and check “Show OSD statistics”. Then click on “OK” to return to the video window, see if it shows what you’re looking for.
/monthly_01_2011/post-56648-12955133580655.png" rel=“”>
  1. Or you can go to ffdshow Video Decoder → ffdshow → OSD, and check the stats you’d like to see on OSD.
/monthly_01_2011/post-56648-12955133747705.png" rel=“”>
Hi Lucy26,
thx for the help with this,
the Directvosub thingy helped alot altho its not the same thingy i used before but it does do exactly the same job.
thanks for all your help, now i can finaly do some serieous work thx to you :wink:
Axelle :smiley:
