MSN disconnects randomly but consistently
so, my problem, i hope somebody can help me with this… is while my bitcomet is running, my msn disconnects me randomly but consistently… when i shut it off, it’s fine… i can’t figure this out, any ideas?..
i am behind a router…
Instant messengers tend to do this. Check your half-open connection limit setting in BC. Normally I suggest 8 but in your case I would suggest 7 since you want to run an IM program. I have mine set to 5 because I do a lot of stuff. My ISP doesn’t like me or my friends.
Thanks for the reply… i’ve put it down to 5, it still does it, maybe not as often… so i try to set it lower, but everytime i do that, it just goes back to 5… any idea why? or is 5 the lowest?
Don’t go lower than 5. At the moment I’m out of ideas because I never got into MSN. This seems to happen with most instant messengers when running BitTorrent.
I have IRC & AIM set to auto reconnect and that seems to take care of things well enough. Its more of a patch than a fix, but it helps.
I have had this problem, and was able to stop it with new firmware for my router. I recall I only had the problem when running bit torrent and msn on my wifi.
I have this same exact problem. I have a linksys router 4 port LAN not wifi. I set the half-open TCP setting to 7 (it was at 10) and it SEEMS to have fixed it, but I haven’t used it for very long.
What is the half-open TCP connections thing mean?
/question
HAH! And I swore to never ask a question before consulting almight google & wikipedia!
"Half-open connection
From Wikipedia, the free encyclopedia
Jump to: navigation, search
A half-open connection refers to a TCP connection that is partially open.
The TCP protocol has a three state system for opening a connection. First, the originating site (A) sends a SYN packet to the destination (B). A is now half-open, and awaiting a response. B now updates its kernel information to indicate the incoming connection from A, and sends out a request to open a channel back (the SYN/ACK packet).
At this point, B is now “half-open” (it has sufficient information to receive packets, but not enough to send packets back). Note that B was put into this state by another machine, outside of B’s control.
Under normal circumstances (see denial-of-service attack for deliberate failure cases), A will receive the SYN/ACK from B, update its tables (which now have enough information for A to both send and receive), and send a final ACK back to B.
Once B receives this final ACK, it also has sufficient information for two-way communication, and the connection is fully open.
I don’t know why my connection would fail if I have only 10 of those half open dudes there. This obviously will slow down my download speed as well right? Is there Denial of service attack that is overloading my router? I doubt it. Any ideas?
changing the setting didnt help
