my Downloads stopp at 99,7%
can anyone help me with this problem, my Downloads stopp at 99,7%??
i heard it can bee something with the router,but what i need to do with the router and whats the ip too get in at the router?
i got an D-link DI-604
if you check the peers in BC they will probably be all the same
this sort of prob is usually nothing to do with the router
if its a video, you can probably play it, by changing the ext. to .avi
My adviceces are, in order:
Check if there are seeds and that you are connected to them.
Stop the file & do a manual hash check.
Be patient.
Hi there,
This faq should help you out: Why my download stops at 99.x%
