My experience, level and title no longer display
After I finally completed the last experience level for “colonel”, my experience level reset to “0%” (as would be expected), but my level and title are now blank, and my experience isn’t changing with activity (and that percentage, of course, normally goes up with activity).
Any ideas?
Thanks.
check your stats on cometID.com, if it’s correct on the website, you can just wait until the stats correct themselves in the client. Usually when the stats don’t display it’s because the connection was interrupted or the server was busy when it loaded, much like when a webpage fails to load.
It’s been this way for about a week. Score appears to be correct on cometid.com.
How many weeks might it take to show/update in the software??
Thanks.
If it’s been that long you might have something blocking your connection to the cometID servers, have you installed any IP filtering programs?
