My listen port yellow
What version of BitComet are you using?
version 1.25
What type of Internet connection do you have (ADSL, etc.)?
Wireless
Do you have a modem? Do you use a router? What make and model are each one of them? Have you forwarded your port?
Modem+router combo.. Innacomm W3400V Wireless Modem from Malaysia
What version of Windows, Firewall and Antivirus do you use?
Windows 7, Windows Firewall , Microsoft Security Essentials
UPnP NAT port mapping: Failed [uPNP device not found!]
I couldn’t find my network discovery.
My listen port yellow.
  1. Posting the same question three times won’t get you more help. I’ve just assumed that the other 2 posts occurred as a glitch from the forum’s side (on occasions that happens) and I’ve deleted them.
  2. Two of the 4 questions which you thoroughly copied into your post above ask: “What make and model are each one of them? Have you forwarded your port?”.
Why did you bother to copy all 4 questions if you only answered 2 of them?
Doesn’t occur to you that if you have a problem with UPnP communication between your router and your PC, then it might help to actually know your router model?
  1. You already started another topic on this issue, which you later abandoned claiming that you’ve solved your problem. Prior to your last post there, you were asked some questions related to your issue, which you didn’t answer. There is no point for all of the staff or the forum to come here asking and waiting for you to give an answer to the same questions.
So, we’ll follow this discussion there, picking it up from where we left it. Just make sure to make a post in there similar to the one above (as Vasy asked you) and try to mention ALL the asked details (i.e. what you wrote above plus router make and model and the status of your listen port on the router).
Also make sure that you give an answer to all the questions you were asked in the previous posts there, so that we can actually make some progress instead of chasing our tail.
This topic will be closed. We’ll be waiting for you… on the other side. B)
