Topic moved
Make sure that you post in the right section of the forum.
And especially don’t jump into somebody else’s thread if your problem has nothing to do with his one.
My WAN is still yellow … i thought one of the key features for BitComet 1.20 is :-
-Intelligent Connection Optimization: Configuration is automatically set to match your connection type.
can anyone help ? first time using file sharing programmes.. kindly assist !! :wacko:
That feature has to do with speed optimization not with opening ports on your firewalls.
For this one issue check this Wiki FAQ topic: I have a yellow status light and my download speeds are slow. What should I do?
plz help .. my WAN is still yellow(BLOCKED) ,port still blocked. I had read through the WIKI FAQs , & anythg from portforward.com but still nth helps.
My Statistics :-
Listen Port of TCP: 63333 (Blocked by Firewall/Router)
Listen Port of UDP: 63333 (Blocked by Firewall/Router)
Windows Firewall: Added [TCP added, UDP added]
UPnP NAT port mapping: Disabled (using static IP,no configuration needed,juz have to tick on static ip column in router)
i m using :
-BitComet vers. 1.20
-Aztech DSL605EW for 2 PCs , mine(Windows XP) is using wireless connections usb adapters WL230USB-L.
-no additional firewall softwares, only Windows default.
-speedtest : Downloads = 1.03Mbps , Uploads = 0.40Mbps
-If i enabled the UPnP port Mapping , i got this in my Statistics :UPnP NAT port mapping: Failed [uPNP device not found!]
-port status probing from GRC =63333(Stealth)(Unknown Protocol for this port,Unknown Application for this port)
i only have an average of 5kb/s ,i dont think it’s right,port forward prob or what??
So,plz tell me what’s wrong!! Help this noob here! anyone plz??
One of the following two applies to you:
either you missed something when configuring your router;
or you still have a software firewall blocking your port.
Therefore, read through the topic I gave you above, and then through the connected links and check your steps.
If you find out you did everything right, come back and explain in detail **every **step you took in order to open your listen port.
