Hi,
Can you tel me where can I find codecs.
Thank you.
Hi,
Thank you.
First I should warn you that installing improper or conflicting codecs can make your system unstable, but if you haven’t installed any then I would recommend getting one of the popular codec packs like those offered by K-lite or CCCP
Hi, Jago, it’s been a very long time!! It’s good to see you!! ![]()
ok, yes I know this reply is about 5 months late, but K-Lite Codec Pack works good for me.
