I am not sure why but recently I noticed I can’t remove 100 percent completed tasks from my torrent list. I hit the red x and select delete task but not file. Then nothing. Task is still in list with green dot.
Using bc 1.37 on win7 64.
Patrick
Patrick
I assume you tried restarting your computer?
Yep. No dice.
My guess is that windows isn’t allowing bitcomet to edit the downloads.xml file, does your user account have admin privileges?
I’ve checked several times using v. 1.37 on windows 7 x64 and it works fine for me.
ps. you can delete all tasks by deleting this file, or you can change the name of it if you don’t want it perm deleted and bitcomet will make a new one with no tasks the next time it’s started. The location of the file can vary depending on your settings and windows version, but for most users it will be in the %appdata% folder under bitcomet.
