Need help for VIP acceleration
i bought the 10G plan today and wanted to try it .
When i restarted the bitcomet and wanted to click on the gray icon of ‘VIP’, it came out this : “sever error. Please try again later” .
Anyone has solution for it ?
Server errors are problems with the server. Pretty much by definition there’s nothing you can do about it – the server must be fixed.
any idea when it will be fix? I also realised that i bought the 10G plan is not reflected in my purchase history.
Well, you could always try again later. I mean, just an idea.
Please be patient, and also send your comet ID and transaction information to Lucy26 in a private message. She can check your account and make sure it was properly credited.
She can also look into the server outage you report.
After trying to download at very poor speeds I paid for the VIP but the speeds didn’t get any better, not even a little improvement. I’m pleased that your price IS very low so there wasn’t much damage done. I see that others are having the same problem.If you could donate my wasted money to the earth quake fund or other good cause I would be pleased. P Baxter.
