Need help ... plz...
Hi guys,
recently I m having some problem from downloading… izzt because I m using the old version 0.60 please help… any1 can give me some advice please…
Hi,
First, yes, I suggest that you upgrade to the latest STABLE version — > .70
Second, could you please provide a bit more information as to what your problem is??
If you want someone to be able to offer help, you’ll have to give details (OS, router, etc.).
Regards,
cassie :slight_smile:
Hi,
Regards,
thanks you… but may I know where can I check my OS, router… sorry because I really blink in using the pc… :lol:
Hi,
O/S (operating system) = windows version
Bit comet versions .59 and .60 have a serious bug regarding dht issues (distributed hash tables) and is banned from alot of private trackers.
We ask that members do not use these versions.
Our latest “stable” version is .70.
I would recommend you not use any version before .64 nor after .70
If you have any trouble usin one of these versions, then post as much detail regarding the problem and we will try to help.
