Hay well ive got bitcomet running and ive port forwarded it but still it isnt connecting to any peers its got the green arrow but it isn’t downloading anything im on 6meg adsl broadband and it isnt the fire wall blocking it so if anyone has any ideas please post them :mellow: thanks.
are you getting any errors in your tracker tab?
are you certain the torrent is active?
What version of Bit Comet are you using?
That happens to me every now and again. I would suggest stopping some torrents if you have a lot uploading/downloading.
I don’t think it really matters what speed your connection is, if there is no one seeding then you won’t get anything back.
