Everything was fine until very recently : I am not able to connect to any remote peers and always get a < than 10 kbs. My port forwarding config are good and any setting haven’t changed on the router nor computer.
I am using 0.70 and pg2 btw
thanks
thanks
Maybe your computers LAN IP Address changed. Did you set up a static IP?
hey, I’ve also gotten this problem, and it’s annoying me, it just happened all of a sudden today around mid day, what’s up with that, is it something to do with my downloads or bitcomet itself. my highest health on a download atm is 2360%.can anyone help us?
Thanks a lot Bitdave, u r right!!! ![]()
now its back to normal.
I never thought about this before
Thx again :lol:
how do you set up a static IP?
wireless router has a static IP, some normal router also has that, dsl connections are also static in most cases
ok cheers, I have a normale router, through a 10mb wire, and I’m not the host computer, can anyone help put it back to normal? is there a program to do it?
