Need help
For some reasson when i have the program running for like 5 or 10 min . the comp reboot it self . Did this happened to anyone ?
Hi,
Which version of ‘the program’?
While we’re at it, why don’t you look at my sig and provide at least some more information? It’ll probably help…
cassie :slight_smile:
Hola
Well the version is the last one , 0.77 , my S.O. is windows xp home edition and i have a cable modem Webstar from ONO , no firewall and i have Avast antivirus but isnt running allways.
Thx :wink:
Hola
Thx :wink:
ok am not a techie but i will give you the same advice i have seen them give countless others try uninstalling the 0.77 version and going with the 0.70 version as it is the latest STABLE release and that may help you… you can get the 0.70 version from www.bitcomet.com.. hope that helps :slight_smile:
Thx , will try that
Just to add a bit: you should never connect to Internet without a firewall. If you don’t have one, you should at least use the firewall that is included with your Windows XP.
Also, you should scan your system very carefully for viruses, trojans, adware and spyware. You should use your antivirus program but should also get and use Ad-Aware and SpyBot S&D, to find things that your antivirus can’t.
