Need some help finding bleach episodes
I need a place where I can find good quality bleach episodes from 230 and up. I have found recent episodes but having trouble with the 230 to 300 range. Can someone help?
Your best bet would be to visit anime websites to find if they could help you with that type of search. :slight_smile:
You can also try entering this text in a google search…
Bleach YYY filetype:torrent
where YYY=episode number
You can also add other description words to narrow the search or any word with a minus sign (-word) will eliminate from search, or example
Bleach 123 avi -mkv filetype:torrent
This will look for episode 123 and prefer one that is listed in .avi container and remove any searches in .mkv
http://watchtvseries.to/
