Need some help
Hey im fairly new to this. I need some help opening my ISO file. I downloaded Poser 6 + Vue 5 (3d animation) off of bitcomet and i need to know how to open it. It says that i need to burn it…but then what. Im also not sure if its a good file cause it came as one.
thanks
mike
I’d say you could try Daemon tools from Daemon tools on their website if u want to try it out b4 burning it. N for burning use Alcohol i dont know exactly the latest version but alcohol wil burn the .iso file good..
Does it burn more then on cd cause i tried to burn it but i had to put it on a dvd. I also tried Daemon tools…wasnt really sure how to do it.
go here it is crude tut but easy
http://forums.bitcomet.com/index.php?showtopic=1210
