I'm wondering if anyone can help ,I've recently purchased the above software and putting it simply ,it is useless ! If I start a burn to disc process it fails three quarters of the way through every time .
I’ve tried uninstalling it and installing it several times .Also tried uninstalling other software that may be causing a conflict .even when I do a test on the dvd it says error starting initializing the process ,whatever that means . I’ve sent system info to Nero three times and I get no reply from them .
I thought it maybe just a couple of downloaded movies but it is every single one .
Can anyone shed any light on this problem for me .
Yeah, just a warning from my experience. Nero does not burn dual layer disc images properly.
For burning of disc images straight to cd/DvD to play in a stand alone player use Imgburn, its the best around, its free, and its by the same guy who made DVD Decrypter.
Thanks for your reply ,I'm trying to burn movies with largely avi,or Dvdrip axxo format
and as far as I can see It’s burning at the correct speed but I will look at that .
I’m trying to burn them so as to watch them on my DVD player .I have been successful on a couple of occasions ,so it works to some small degree but largely it fails .
I understand what you say about aXXo ,Im largely using dvd rip and avi and it is literally every burn that fails ! I've uninstalled nero 7( I was trying to burn with nero vision incidentally )and I've tried
imgburn but even that keeps stating that it is an unsupported file or format .I am at a complete loss with it all .I’d have thought it was maybe just one or two not so clever formats …but not everyone !
I will try the links you suggested and I’ll hope for best .
