nero 7 premium
Hello everyone ,
                   Just wondering if anyone can help me .I'm downloading movies and t.v. shows from bit comet .that's the easy part .Then I'm trying to burn them onto disc to watch on my regular dvd player/recorder .I've managed to acheive this twice ,but 99% of attempts have failed .With nero 7 about three quarters of the way through .I've tried other software (imgburn) and that won't even recognize the file or format !
I’m wondering, is there some kind of a restriction on downloaded video .They are largely avi and dvdrip files.
I’m at a complete loss with it all. Any help would be appreciated
Regards Tadano
P.S I’m using DVD-RW discs if that has any bearing on it .
Dvdrip is not a file type, AVI is.
I hope you have a newer dvd player if you want to play a dvd-rw in it.
Have you tried using dvd+r
Make sure your burning at 4x or less
Also there seems to be a lot of problems with Nero 7
maybe try finding the latest version of Nero 6
