I’ve used BitComet 0.70 for quite a while now, and there’s been nothing wrong with it, but all of a sudden there’s no connection. I’ve checked the internet connection and it’s still connected.
Down in the corner it says “DHT not connected”. Can’t really figure out what that means, but it’s always said that, even though BitComet was connected, so I just thought it was some mistake…
Anyway, I’ve tried restarting the computer and uninstall and install again several times, and it hasn’t worked, so maybe you could give me some sort of advice of what do to..?
Well, the situation has changed now… The uploading is fine and running 30 KB/s, but the downloading is not at all, for some reason, even though I am downloading stuff. This is just getting more and more confusing…
Sounds like the torrent your downloading is dead, has no more seeds, or very few seeds and they’re currently uploading to someone else. Try downloading a really popular torrent and see what happens.
Wait… It actually started working now. What the h***. :huh: I didn’t do anything and it started working again.. That’s just… weird. Let’s hope it holds up this time. <_<
But thank you all very much for all your help, I really appreciate it.
