dejo de loguearse automaticamente y lo hago manuel pero aun asi nada soy usuario desde 2012 y no le encuentro solucion
**Title: I can't log in to CometId**
It stopped automatically logging in [so] I do it manually, but even then, nothing.
I've been a user since 2012 but haven't found a solution.
Sorry, but even his written Spanish is atrocious… I guess all his punctuation is missing from his keyboard… To say nothing about his careless (lack of) reading capabilities…
Ruego que la próxima vez que escribas en español lo hagas en el foro que tenemos para ello... es mucho más fácil detectar cuándo algo necesita ser traducido.
Éste post será movido cuando se termine de responder.
_**[Foro Español - Spanish Forum](/forum/33-soporte-t%C3%A9cnico-tech-support/)**_
Good evening.
I beg that the next time you write in Spanish, you do so in the forums that we have for that purpose...it's much easier to detect when something needs to be translated.
This post will be moved when it has been answered.
I declined to respond to this post after seeing how little effort the member put into this post. I was hoping it was google that made it seem illiterate, but perhaps the translation was accurate and the fault is with the member.
