no remote peers
i am just wondering how come i never have any remote peers? i am using kerio firewall, disabled windows firewall, i have a speedstream 4100 dsl modem, no router, can’t find any thing on my computer that has a firewall, and i am using avast antivirus as well as avg free. i get reasonably fast download speeds (up to 110kb/s) but am always l;ooking to get more :stuck_out_tongue: . any ideas?
If you’re not getting any remote connections, something is blocking your listen port and nobody can connect to you. That means you have a firewall you don’t know about, that you’ll have to find and open.
okay, i’ll check in to that. in the mean time after i started this post i beag downloading a torrent by axxo and for some reason i can only connect to only a few peers. am i being blocked by other peers or something? i usually get about 100 kB/s, now i’m down to 16! i haven’t changed anything and i usually seed to 2.5 or better so i don’t know whats going on. any ideas?
If you’re using Kerio then you have to make a rule for UDP traffic as well.
how do i make the rule for udp trafic? sorry for being stupid but i am a noob when it comes to kerio.
edit: it looks like i already have a rule for udp traffic. below is a screenshot. does everything look right?
