I’ve got ADSL 256 kb/s, Sagem modem (F@st 800/840) with v3.0 drivers (Installed as USB ADSL Lan Adapter) I use cFos v.7.0 to connect internet, BitComet 0.7 to download, and Windows Xp with Sp2 as OS. I know about the connection limit, and I’ve already set it from 10 to 100. When I’m downloading ANY torrent, I can’t connect to ANY of the peers (I’ve tried with many different torrents) , although there are plenty of them. I usually have 20 kb/s dl speed and 10kb/s upload speed, but now they’re both at 0. Turning off the XP firewall doesn’t change a thing. These are the my settings:
Connection
Global
Global max download rate = unlimited
Global max upload rate = 10 kb/s
Task Schedule
Max simultaneous download tasks = 100
Automaticly start a new task if download rate below = 10kb/s
Listen port=15898 (chanching it doesn’t change anything)
No proxy
Task
Do not prompt when add new ask = no
Allocate disk when add new task = no
Add .bc! extension for incomplete file = yes
Delete 0 byte files when task is removed = yes
Display task delete confirm dialog = yes
When download is finished
Hash-check again when download task is finished
auto stop task when share ratio reaches = no limit
do not auto stop task when seeds less then = 5
shut down computer when all task are finished and auto stopped
Upload
Maximum upload rate per task = no limit
Minimum upload rate per task = no limit
Minimum upload rate per seeding task = 3 kb/s
Chatting is disabled
Avanced
Check for updates on startup= yes
default bittorrent client = yes
disable torrent confirm file download dialog = yes
set hash check thread to low priority = yes
add dht network as backup tracker =yes
add backup tracker if connection isn’t estabilished in 1 minute
backup trackers = none
Connection
Enable DHT network = yes
Enable Nat/firewall configuration in ics/icf (xp only) = yes
Enable unpn port mapping (xp only) = yes
Remove ports on Nat/firewall (xp only) = no
Maximum connections per task = auto
Connections to keep per task = auto
Global maximum upload slots = auto
Global minimum upload slots = auto
Socket send buffer size = auto
Socket start interval = 300 ms
Max open tcp connections = 100
use nat traversal via udp = automatic
protocol encryption = auto detect
Ip rules
Enable reporting lan ip to tracker = yes
enable ip filter file ipfilter.dat (compatibile with emule) = yes
max sessions per ip for downloading task = 3
max sessions per ip for uploading task = 1
Disk cache
minimum disk cache size = 100 mb
maximum disk cache size = 200 mb
shrink disk cache if free physical mermory lower than 50 mb
auto choose cache size in given range = yes
If anyone need more config specification, fell free to post a reply
If anyone can tell me how to improve my Bitcomet performance, basing on my configuration please post a reply too.
