none connection
Hi to All
My name is gof_3 and am new to the forum. :slight_smile:
My problem is with trackers etc: it says "an established connection was aborted by the software in your host machine, also I get this to UDP Tracker no responce :frowning:
Hi, can you please review the ā€œREAD THIS before postingā€, and reply with the details regarding your computer and bitcomet versions.
I’d also like you to prepare a screenshot of this error message. If you don’t know how, I believe we have a guide for making and posting screenshots in the guides/tutorials section.
Lastly, does this happen with all torrents, or just one? if just one, can you please post a link to where you got this torrent so we can examine it.
TuuS
Thanks for you reply sorry if I poted wrong but am new to posting.
I am using Windows XP serv. Pack 3
Bitcomet ver. is 1.14 I keep it updated to latest ver.
internet connection is ADSL2+ using a modem only all ports are forwarded correct hopefuly
Using windows firewall only, download speeds are ok set to unlimited.
Antivirus used is AVG 8
This problem has occured before in other versions of Bitcomet.
Thanks also for info on screenshots never did that before.
The tracker you’re trying to connect to has been experiencing problems. You should try again and see if the issue persists. If it does, what antivirus application are you using?
the antivirus I’m using and have used for some time now is AVG 8.5 licienced.
Have also noticed SumoTorrent does the same.
Gof_3
