Hey guys, I finally had the time to try out BitComet, but I need some help. I installed 0.73 and I was able to search for files, but at the bottom of the screen it says that I am not logged in. How do I start to download and upload files?
Thanks
Thanks
Hi there,
Do yourself a favour.. revert to version 0.70 <— it’s the latest STABLE version. ![]()
(The newer ones aren’t, and have too many bugs that still need to be ironed out.)
Regards,
Do you have a link for it? Plus, do I need to install anything else when I download it?
Try going here
http://forums.bitcomet.com/index.php?showtopic=2830
When you’ve done that, try reading through our How-To Guides and FAQs.
Luck. ![]()
You da man, thank you.
