i downloaded the latest bitcomet after using the old one with no problems and after getting .70 an annoying norton window keeps popping up asking whenether to permit bitcomet, i’ve tried selecting both choices but it won’t go away and bitcomet keeps downloading anyway. Are there any solutions apart from uninstalling norton/bitcomet?
I have the same problem. I previously had version 0.57 and everything worked fine. But now I get those Norton Worm warnings nonstop. I couldn’t make it stop either so I’ll probaly go back to ver .57 cause its annoying.
Open up Norton AntiVirus
Select Options
Select Internet Worm Protection
Select Program Control
Delete BitComet entry
Next time you start BitComet, it should only ask you once whether to permit or not.
Select Options
Well im not getting the alerts… but its still not dloading ~_~
These are not bugs in BitComet.
For Norton see this post in the FAQ: http://forums.bitcomet.com/index.php?showtopic=347#
There are also other guides in the Guides and HOWTO’s section that you guys should try reading.
Or could learn how to set your software and possibly hardware up. See the above link for the Guides section.
Thanks to both of you. I fixed the Norton issue and learned some new things in those guides.
