Not able online after open listen port
I have issue to use internet explorer or any other messenger tool after i open my listen port. I’m able to download using bitComet but other software all not able to work.
If i close my bitcomet, then other online software able to connect.
I follow all the step in Up to date BitComet Speed Guide under How to and setup the listen port in port forwarding.
My version of BitCom is 0.61. I’m using D-link-500T.
Please advice.
First thing to do is upgrade to the current stable version of BitComet, v0.70.
Please make only one change at a time, but another thing I would try is to bypass your router, connecting direct to your modem to see if the problem is your router, or its settings.
I’m not sure about that model, but I suspect (by the model number) that its an older model, so there is likely a firmware update. I will also add that dlinks tech support has always been willing to help with such issues, even if its an older model, or even purchased second hand.
