Not able to Download any Torrent file?
I don’t know what settings I need to look at on my OS or Router?
Win 7
Norton 360 v3
Westell Router from Verizon
Win 7
Norton 360 v3
Torrent files are being downloaded through your browser most of times.
What do you do and where do you get stuck?
I think you need to clarify if your not able to download the “torrent file” (a very small file with .torrent extension) or are you unable to use the torrent to download. Your post says its the former, but I suspect you meant the latter.
If your unsure of what your doing and cannot describe it accurately, then I suggest you take the time to write exactly what you are doing, step by step starting from when your computer starts up and we should be able to tell you what has gone wrong.
