Hello,
I have the latest verion of BitComet (0.77) and I’de like to ask
for the meaning of the “Not loginned in” icon in the bottom screen.
what does it means?
Thanks ![]()
/post-16975-1163944253.jpg" rel=“”>
Hello,
what does it means?
Thanks ![]()
there was released the chinese version of bittcomet I think… it contains chinese torrents and stuff…
dawin45, sorry but I dont think I understand you:
I have a regular version and not a chinese version .
/post-16975-1163944919.jpg" rel=“”>
no i meant there is a japanese or chinese bittcomet related site,or torrents site I’ve loged in there but I couldn’t understand anything, it doesn’t have anything to do whith the language of youre bittcomet client…
As has been very frequently mentioned in this forum, this is a problem with later versions of BitComet beyond the last stable release. Unless you are beta-testing and expecting problems, then you should be using the last stable version, which is 0.70, and stay with it until there is another stable release.
thanks kluelos, I didnt notice it a beta verion.
In the DL is is written: " BitComet_0.77_setup.exe " . no beta version is mentioned ?!
in the “about” menu written:" Stable release".
but Im back using v0.70
/post-16975-1164004377.jpg" rel=“”>
You are partly correct, as the new client wasn’t released as “beta” version officially, but since it has sever problems, it was reclassified as “less then stable”
Our download page states 70 as the latest stable version.
Regarding the “not logged in” message…
This is a new network for bit comet users, however, at this time, it is only usable in Chinese.
After the unstable issues are resolved, and the other features are enabled, I’m sure this will be expanded to other areas.
Thanks “The UnUsual Suspect” ![]()
