Not Loginned in ?
Howdy how from a newbe on the forum…
Well here it goes.. i got my self a new computer and installed BitComet
But when i try to download something, nothing happens :o :o :o
But i says “Not Loginned in” on the bottom of the screen?
someone nows what to do… have been trying to find it on the forum but no luck :frowning:
LeFTy
if you made the unfortunate mistake of downloading v0.71 unistall that and download v0.70. that should take care of it!
Stay away from 0.72 as well.
i’m juz dl ver 0.72 n i had the same problem as Lefty.
why can’t use ver 0.72 though it’s the latest version…?
The latest STABLE version is .70
We are all sorry for the problems members are having with the two newer versions.
ic, thanks.
Q: if i can’t find a song via the bitcomet, can i post a post/thread at this forum to get some helps?
we allow such posts in the lounge area.
