i downloaded fm2007 but i dont know what to do next. there is a whole heap of rzr files so i have no idea where to go from here. your help would be great guys for this and anything in the future.
I will assume you mean “rar” not rzr.
If so, get winrar (google can find it for you)
Extract the first part, and it will unzip them all.
na mate i kow what win rar is. these files are rzr ??? there is no set up files or anything very wierd…
Please provide a link to the page where you downloaded this torrent.
I will have a look when time permits
[/quot
Are you sure the extension is .rzr?
See here
I think Suspect is correct, you need to use Winrar to extract the first file in the sequence and it will automagically extract all the others.
Then you need to figure out what to do with the extracted file(s). If you need help with this then please tell us the extension of the extracted file(s).
I have a sneaky suspicion that this is a console version (SEGA or some such), not a PC game, and that may be causing the confusion. Could be wrong.
