Nothing happening
hi,
got comet installed, Ive put 4 torrents in there using magnet,
but nothing seems to be happening
on firewall, comet is there as an exception so dont think the firewall
is causing the prob
follow the first link in my signature then reply with all the required info and we’ll try to help.
thanks for the reply, Ill have to check it out later… fill in the form etc
since my post I re installed bitcomet
the downloads started working, and 4 big torrents downloaded
so I thought things were getting back to normal
since then however things have gone quiet again, despite having many torrents on board
that I know have big numbers of seeders and leechers… I keep seeing at the top of
the window … downloads 0 uploads 0 !
Its a mystery !
It’s only a mystery because you haven’t provided any useful information.
ROFL!! :smiley:
Man writes to his car dealer requesting service on his car that is only described as “not working”
man: greetings, my car doesn’t seem to be working
Service rep: Hello sir, please look in your glove box for a list of questions we include with all cars and answer all of these questions and we will be glad to help you.
Man: Ok, sounds good, but before I go to all that trouble I changed the oil, rotated the tires, waxed the paint, and it still doesn’t work, it’s a mystery.
can’t imagine why someone would reinstall but not spend 30 seconds reading a list of questions
I had the problem a while back, and turned off all wake on lan and power management on my network driver.
