I can’t dowload any films or music from my bitcomet, nothing comes at all … I have installed the Bitcomet device, and when i want to download anything from T411 for example, everything works perfectly, but everything stays at “0” as you can see in my attach print screen.
Your “seeds/peers” column shows that there are none connected and none available. Either you were unable to connect to the tracker or the task is dead. I’d check the tracker tab and see if there are any error messages. If the tracker/s connect and return 0 peers, you’ll need to find another torrent. If there is a connection error post it here .
