im not the first one , but i may have a unique case here !
Okay, well. I have a modem + a router.
Modem = D-Link DSL 502T
Router= DSE Xh9948
heres how it goes,
wall - modem - router - laptop.
i have random cables joined up to my modem, then the single ethernet cable port is plugged into my modem,which is then plugged into the main port in the router, i then have a second cable from one of the four ports in my router, into the back of my laptop.
I have forwarded my modem, and i still have a yellow light, am i needing to forward the router too?
If you forwarded the port on your modem, it means that your modem is also a router itself (actually a modem+router combo device).
If you have more than one router daisy-chained up to your computer youāll need to forward the port on every single one of them.
Just make sure that on every device you will forward the port toward the IP address which is used by the WAN interface of the other device downstream. (I.e. on your modem you forward the port toward the fixed IP you did assign to the WAN interface of your router. You did assign a fixed IP for the WAN interface of the DSE router, as you would for any computer connected directly to the router/modem, didnāt you?)
Or (if the option exists) put the modem in bridge mode and perform forwarding only on the DSE router.
Haha, and again. Trying to setup a static ip for my modem this time.. It makes whole of my internet screw up. Then it doesnāt respond AT ALl , so i have to unplug it from the wall for 20secs then replug it in, then it resets its IP then it turns into a loop.
Lmao, friend told me to fiddle with the āSet global limitsā
and i set it to 100MB LAN/FTTB
boom, instant 222kbps download speed. no need to port forward. i know thats not the best speed, seeing as everyone else is going at 700kbps, BUT i dont have unlimited internet speeds.
still wanting to know how to port forward though..
uPnP (universal plug n play) is a good thing when it works, but since not every router manufacturer implements it the same, itās impossible to make a software application that can enable it on all routers, and diagnosing why it doesnāt work is always much harder then simply forwarding your port.
You got lucky having a router that works with uPnP, so happy downloading
Must have jinxāed it or something, last night, port decided to un-forward itself somehow. Happily downloading at 900kbps , then everything turned bad. uPnP stopped working, port wasnāt forwarded anymore, speed drops to 20kbps and i accidently randomized my port..
I got a new port, forwarded it on my router, my modem, my firewall, everything, enabled uPnP on both routers/modems and uPnP isnt working either..
BitComets uPnP is reaching my router and registering its ports .. but isnt letting BitComet use them?
Any explanation for this?
Help appreciated..
EDIT: When i exit BitComet entirely and reopen it, it has a green light, till i checks again, then it says, its blocked again..
it goes yellow when i start my torrent again, not sure if this is normal .. but its driving me insane.
As explained above, when UPnP works, itās all sweet.
But when it fails itās pretty hard to troubleshoot.
So pick up your tools and go back to manual port forwarding as you were told in the first place.
Or, of course, you could stand by it and ask it nicely, perhaps it will turn green again. Itās the easier way.
Haha, yeah. Iām just gonna stick to this speed for the last gigabyte. Iām sick of all this port forward the port, then the router, then allow the firewall blah blah blah. Wish it was so much simpler aye.
