:huh: I’ve been keeping the older downloads of programs as well as the updates on the home page. I’ve deleted some of the movies or CD’s I didn’t like but; example: Downloaded BitComet_1.17_setup.ex(BitComet). then I upgraded to Bitcomet_1.19_setup.ex(BitComet). Am I suppose to delete version BitComet.17? Same thing with VLC media and a few of their upgrades; should I keep the latest version and delete the rest or will that affect the way the new version it works. I’ve got 39 torrents on the home page. Is that too many listed but if deleted I’d lose the files wouldn’t I? :unsure:
Of what homepage do you speak? I can’t gather what you’re saying.
Whether you keep or not the installers of the applications you downloaded is irrelevant both for BitComet and for the respective applications. The installers are just for that purpose: installing. They are not used for running the application.
So far, all old versions of BC are available from the main website, all the way back to 0.5x. There’s no particular need to keep older versions on your disk too. I hope that BC will announce, far in advance, if it ever intends to take the older versions down. Meantime you can get any of them there if you need them.
