Hi all, need some help… I recently reformatted my system carfully saving all of the torrent and xml files aswell as the partially d/l ed files. I have now placed these files back in their respective folders but they do not apear in transfer list. Is it not possible to resume d/ling the files this way…Pls help
Docta
Make sure you have done everything from post #12.
If you changed the download folder from "C:\Program Files\BitComet\Downloads" to something else don’t forget after the install to change it back to the folder that it was: “options->preferences->task->download->default download path”. Make sure that all *.bc files your unfinished torrents are in the same folder that “options->preferences->task->download->default download path” is pointing to.
